Anyone ever tried using a AT&T IMEI on the F21 with American bands?
I used the IMEI that came with the phone on dark star US Mobile
And my friend used it with direct AT& T with the IMEI that came with the phone
We both had no issues
Did it work better than Verizon and t mobile?
No Verizon was the best
I flashed the tiq M5 super onto a qin with fastbootD. Now it’s just bootlooping. Does that mean it’s not compatible?
I did a reset in recovery already.
incompatible and even if you get it to turn on the touch will not work
Do you know how to unlock the bootloader on the Qin f21 pro?
Welcome
use MTK client
I have a friend who just returned from Israel for a week with a qin f21 pro using triple tel And it worked! No problems at all.
That is generally not the case as of my experience
I have Verizon direct cdma less enabled and still have issues, tech said I need to get a Verizon IMEI. Any advice?
Take a IMEI from a kyocera or some Verizon approved device preferably one that’s not being used anymore
What do you mean that you’re still having issues? No service at all or spotty service in basement and random places?
Service goes on and off, only outgoing calls (sometimes) and zero messaging
Is there like a guide how to do that, and will it wipe my phone?
You will not wipe your phone
lol
adb shell "getprop ro.product.model && getprop ro.build.display.id && getprop ro.boot.vbmeta.device_state && getprop ro.boot.verifiedbootstate && su -c id"
F21 Pro
A666_V0.0.5_20211202
locked
green
uid=0(root) gid=0(root) groups=0(root) context=u:r:magisk:s0
To be clear, I’m not laughing, tried to change to a
or a![]()
Since when can’t you change them
works for me to change it
I dunno
