Qin F21 Pro General Thread
Phone doesn’t turn on and I can’t flash sp either
Autobooter fastboot?
Didn’t try thanks I’ll give it a go
Doesn’t the phone need to be powered on to go into autoboot?
Nope no good
I think it’s supposed to be off.
Is this referring to the F30?
Yes
Well the F30 was out a lot before September 2025.
The service became really bad again and I hope to reflash it soon. It keeps on connecting and reconnecting and it’ll say server unreachable even with all bars… the problem is that I missed some important sms messages and phones calls. I use google messages for texts. Any way I can still get the texts and see the missed calls that never came through?
Seems like from what you described CDMA less isn’t enabled reflashing won’t help
Regarding getting your messages you missed I do not believe there is a way
You can usually get them for 3 or 4 days after if the messages wern’t delivered
How?
They should come in automatically
Does anybody know someone,
that i can give(to flash) or buy a few qin f21 pro FLASHED for usa bands for cheap,
i will order a few @a time but eventually a lot,?
…because i do not want to brick..
do you have the phones that work with us bands
if so contact me at 281-691-2421 i can help ill teach you how to do it its super simple
@dfrydman Very nice of you,
Will definitely get in touch at some point,
I do not know ANYTHING** about coding **
Is this the older version that can be flashed or is it the new version that can’t be flashed??
U can’t tell from that you need the serial number
how do i find the serial number?
