I need empty vbmeta for a qin. Flashing stock. Then dumber os. Anyone has?
Empty vbmeta,
Do you need anything else?
I flashed stock with format and download
unlocked bootloader
disabled vbmeta
fastboot reboot fastboot
fastboot flash system dumberos
pulled boot patched and flashed it
Trying to set IMEI and switheroo app doesnt detect nvram.
I need israeli bands does anyone have those files with generic imei i can change after?
The bands swap repo has it as a tar I believe. You can get it from there. It’ll have generic IMEI and identifiers but once it has something (not empty) the IMEI switcheroo thing should work.
Idk if connected but snwriter doesn’t work on dumbdroid either
I don’t think it has to do with it. A fresh flash leaves you with an empty nvram so it doesn’t work with the app.
Anyone know whrere the cheapest place is in jerusalem to buy one of these?
In Davidka (this is a square in Jerusalem) there are several Stores
https://haimke.co.il/shop/תומך-כשר/דגמי-שיאומי/שיאומי-חצי-טאצ-f21-pro-מהדרין
This is a very good store And cheap, but I don’t know what port they have, try calling them.
All davidka stores sell the same things, feel like the same price and will scam you out of your life savings. (Not literally, I was joking, but some are creepy and raise prices just because you’re an American)
“I’m American, not stupid” usually got me what I needed (non phone related, just your average daily stuff) ![]()
I really recommend this store. I’ve bought more than 10 phones there and it’s the cheapest place around, however you can’t negotiate the price
How much?
430 ils when i went
