Qin F21 Pro General Thread
Did anyone try to replace the antenna with a one more compatible with US bands? (Is it even possible?)
Might be easier to manufacture a new phone. I don’t know enough about this stuff but I’m pretty sure the antenna is part of the package deal with the CPU etc and with together. I don’t know if it’s possible to mix and match. Besides the firmware would probably be a nightmare to get working after doing that.
Again I don’t really know what I’m talking about. I’m just assuming from the little I worked with the network firmware
Do I have to install mtk drivers to use fastboot / bootloader
whats the highest version android i can flash a f21 pro to?
Absolutely
14
Dumbdroid.
would you know whats the best modified Dumbdroid rom that works with amarican and isreali bands?
What do you mean by “modified dumbdroid”?
Does the default dumbdroid rom work with American and isreali bands?
I saw in other threads that people modified the dumbdroid. No?
Nah.
And there’s no such thing having american and stock bands.
Prob need the bands reflashed. The whole modem file package.
I’ve had that and this fixed it.
Uber Eats not working on Qin f21 with tripleUMDM. When I click on an item the screen just goes to a blank white with just the firsst letter of the item written in the top corner - the rest of the screen is just white. Any idea whats going on?
Do you have play store hidden?
Yes, but even when I enable the play store it still doesn’t work. I also have in-app browser enabled, but still doesnt work. It used to work but then suddenly stopped. Tried uninstalling and reinstalling. Doesn’t work.
I use Uber and Uber eats webapp. Pretty much identical, and much more lightweight. Give it a try.
Was it working before tripleumdm? If not I’m pretty sure it’s an integrity issue.
Or what @creed said
I believe they themselves are web view apps and you need to make an exception.
Might be wrong
I enabled WebView exception already. The whole things a little weird cause it used to work…
Anyone know a good place to get a replacement screen?
sorry to go back a little but once you corrupt your preloader you got yourself a nice brick to add to your fireplace because all those modes like preloader and fastboot both connect preloader to get sp to work though sp might also use brom which is before preloader or maybe try a cm2 so you might be able to remove it from your fireplace and make it into a phone again but most likely its best use is as a brick for your fireplace @ars18 can you confirm?
I think this is the cheapest
You have a guide here
There is a small part that is not explained in the video
I can send you another video in PM
