Aha interesting
I’m pretty sure the f30 has something in the software that makes it that you don’t need to turn on CDMA less…
Aha interesting
Using Verizon direct didn’t have to activate CDMAless on f21 1.1.1 and 6.1.3
Huh
Only for us mobile Verizon?!
Did it just happen once by coincidence or it’s a fact…?
Used us Mobile Verizon for a while and never had to call again. Same thing with SafeLink.
That I understand certain IMEI u only have to call once…
IMEI numbers from newer phones
Using the same IMEI as my TCL flip 2
Anyone know how I can download for example capitol one banking app when I’m in Israel, cuz certain apps are not allowed in different countries, I tried a VPN it didn’t work any other ideas?
I’m using the app (capital one) in Israel. It updates here no problem. When or where does the error happen?
If it’s just installing, I can get you the APK file if that helps
Some apps you can’t install when your in certain countries like Robinhood you can’t install in Israel but if you install it in America it’ll work but you can’t install it in Israel
Never heard of that, but if that’s the case, VPN should fix it. If it doesn’t, I don’t see how it can be that that’s the issue.
Found a solution i used Aurora Store
When I did it from my computer originally I installed like three differnent MTK drivers but I can’t remember which was the last/best one that I installed.
I’m setting up a new laptop now, which driver should I install?
My friend is buying a f21 of someone, idk what rom, he bought it in Israel.
Quote from the seller:
When I put in any type of SIM card the phone doesn’t detect that there’s a SIM card in there there’s no notifications or anything the phone stays the same when I put the Sim on when I take it out it just doesn’t detect it that there’s a Sim
Any insight?
Totally hardware.
So he shouldn’t buy it…
No he should not
Does at&t work on the f21? 6.1.3
yeah
Is it working good in Switzerland?
