How does the Qin F21 show Hebrew Date on the clock launcher widget? Is it only specific ROMs? Which ones? Can it be toggled on/off? Is it a modification to the clock apk?
Is it possible to add rotating screen option in the QS tile?
Automatic - No. You have the TripleRotate - Screen rotate for our junk phones without a G-sensor
My New F21 Pro (December 2025, hw-revision ca01) has a corrupted preloader. Screen doesnโt turn on, just vibrates. MTKClient detects it but keeps saying โhandshake failedโ. SP Flash Tool doesnโt detect it at all. How do I recover it? @ars18 @TripleU
What version it is ?
If you need help identifying ![]()
Its V2 but SPflash tool wont flash the softwareโฆ
fastboot ?
you can use autobooter
Ty
Where do I download autobooter and what are the steps to use it?
Is still wont turn on
Will it put your device into fastboot?
Dont think so, screen didnt turn on
What exactly happened when you ran autobooter ?
The exe just showed the dots it showed an unlimited number eventually I unplugged the phone
Itโs supposed to boot your phone into fastboot do you have the mtk drivers installed on your computer ?
If you do not have drivers installed that may have been your issue all along
What ROM are you running? Did you ever flash anything to it successfully, or did it come like that?
What do you mean that they do it automatically? Who doesnโt automatically??
not sure all i know is when i gave them an imei that passed in their system than they set it up and i didnt have to tell them anything about cdma less
