Screen rotate for our junk phones without a G-sensor
Simple and straight forward. When the app is installed and permissions granted, an icon will pop up in quick settings aka status bar extended. Tap to rotate.
Good for Kosher ROMs if you know how to integrate it…
Enjoy!
How do I install it?
Regular adb install failed
Probably need to sign it
Hi thanks for the app.
It’s pre installed on @ars18 and @TripleU 6.1.3 ROM so it doesn’t come up at all in the quick settings bar
Yeah i see I tried installing it it fails because I have it already installed
