Qin Selfie Camera Option Gone
Anyone know why on the Qin F21 Pro sometimes the selfie camera button goes away in the camera app and now selfie camera is unsuable?
It’s happened a couple of times on different phones so it can’t be hardware problem
Funny, I just had a customer with that exact issue. Any idea what it can be?
Sometimes the selfie camera disconnects itself from the green board, so you just have to open the phone and connect it back on the board.
Very easy to do.
NOTE: Before doing anything remove the SIM tray, otherwise you will break the SIM tray and the phone
Make sense. Not sure why OP is assuming not a HW problem….
This isn’t reddit
I have a name
I just found it weird that this is happening to a couple of phones
Lol ok @DonBot. Sorry, just found it quicker to type that…
Ok but it also sort of makes sense for a weak point of the hardware to be present on more than one device I guess…
When I tried in the past several times it didn’t work
I had this with several phones and I tried that and I tried replacing the selfie camera module it didn’t help
did anything work?
On my f21 selfie doesn’t work in camera but works in other apps…
Nope also I had this with a f30
any idea if factory reset will help?
I had it already a few different times and it always helped.
in my experience no
Im Genuinely happy for you and i hope that for everyone else here it will also work
so i have the button for it, but when i press it it stays on the back camera.
also in other apps…
My friend says his camera totally stopped working since he came home from Israel anyone know why?
It has nothing to do with its location, the camera has no bands.
Maybe the phone broke on the plane​:rofl:
the camera probably disconnected open phone and reconnect
Ye thought the same just he was driving me insane so I just did mine and asked
