Small Questions that don’t deserve their own thread go here
Is it possible to PM a GitHub user?
When you connect to a filtered ISP’s WiFi,
you will not have internet access on your device unless you install a CA certificate.
If you install as a normal user, it will only help some apps, rooting doesn’t help everyone either, but it helps the vast majority of them
Can someone patch this boot IMG with Magisk?
BOOTIMG.bin (6 MB)
I am looking at the partitions of a device via mtk client. I don’t see the vb partition. Does this make sense? Is it possible it has a different name?
if I set a webview to 0dip would it be picked up by screen readers like egate? not that I that I care practically, just curious
anyone know why https://app-builder.madrichim.ovh/ isnt working?
I noticed that too. You can try building from the GitHub repo manually. Should work fine.
Do you have a GitHub account?
You can fork the original repo and extract the zip below and build with GitHub actions.
build-apk.zip (486 Bytes)
First time I did this, I’m sure it could be done better. Very cool.
If you want it set up already, just fork mine:
To my knowledge, it doesn’t work. When you reach the limit, it tells you to upgrade.
It’s a risk of losing photos and should be taken seriously.
Been using it for years, no issues. 50 something gigabyte uploaded.
Interesting. Let’s be more specific. The pixelfy module - which has the same feature and most probably uses the same hack, didn’t work on a f21.
I don’t recommend pixelfy. Stopped working normally a while ago. This one is solid.
Gotcha, ok, moving thread
Every hacked version of mt manager gets detected by windows as a virus.
Why?
can anybody give me the package names of these apps on a qin F21?
- Messages
- Contacts
- App Updater (aroura)
- Camera
- Gallery
Thanks
Messaging: com.android.mms
Contacts: com.android.contacts
Camera: com.mediatek.camera
Gallery: com.android.gallery3d
Aurora Updater com.aurora.store
Tzadik
Aurora Updater package name is the same as original aurora store.
com.aurora.store
