Revanced
Dunno how they do it without breaking
Why?
Revanced
Why?
Cuz @MJZ is trying to block Texting in Google Voice using for Calls only
@Air_Condition150 down to test another app I just made? Also anyone with a Kyocera e4810 WITH WAZE able to test?
Im ready
Ok I’ll pm you a drive link
Sure
I’m at the point where I can pay a pre release
What does that do?
much better version has new features like auto fill search and memory for the last 20 searches and nicer ui
I’ll make a new thread on detail
Check here for updates and more details
I went into engineer mode ony qin f21 I may have by mistake switched a few things I know nothing about,
Would reflashing the bands partitions and then rewriting the IMEI reset everything in there to default?
Yes
Does the TCL Flip 2 let you install apps to a microSD card?
No
Someone post something in https://forums.jtechforums.org/t/tech-memes-memes-that-only-geeks-will-get/4437.
Its locked on my side
I would love to, but I can’t post there. Once I reach trust level 3 then I can…
Posted, you know you can put more then one image in each post…
