in the egate reseller portal - whats an api key as oppose to a software license
whats “custom value“ when making new software licenses
anyone has cat s22 gmail apk with blocked WebView?
not possible
ok thanks anyways
anyone know if its possible to have a claude agent run adb commands?
Yes 100%
That’s how I do my debugging, much faster than me filtering through logcats.
how do you set it up? i have adb in path but it says it cant access it (i don’t have much experience using cli ai tools, so not sure if i have to set anything up)
tried making an agent that runs a logcat too
Windows? I dunno
Direct it to the platform tools folder as a rule
Cyber-Deck time? I wish I was a 3D printer guy.
N100, 16GB DDR5
I want to skin everything and put into a clamshell case.
im made a backup using adb and now i want to restore it (adb restore my_backup2.ab) and it seems to work the prompt shows on the device and it runs for a couple minutes stops with no errrors and the backuped things dont show up
Which Android version?
ADB backup has been deprecated and unreliable for a while.
its android 11 - i ended up extracting the backup and manually puting on
https://github.com/Fleishigs/K-Pod-Android-App/releases/download/v1.0.0/app-debug.apk
can the oilam give me feedback on this its k-pod in an app much better then web in my opnion and downloads go to music
New laptop incoming, did not realize how much these are worth and I’m sitting on quite a bit ![]()
@Dev-in-the-BM_2.0 I gave you a gold mine haha
@TripleU u too
Don’t sell now, wait for prices for RAM to go up.
DDR4 is sometimes more expensive than DDR5 because of lack of production
Thought about it, but decided to put up for auction.
You got close to 300gb if I remember correctly, no? 200?
Didn’t put all, just some.
16GB modules are going for 50-60 a peice on eBay.
