I’ll give you a Lenovo dock too for it
@DaWelch it was also my work PC for a while
It’s missing a key like the first picture. This is an old pic
@DaWelch you’ll need to use Ethernet or Wi-Fi adapter, don’t remember if I nuked the antennas
Boots by default into duplicate?
What?
I dunno, but I’m taking out the drive, you can install whatever you want on it
Please install Linux on it lol
Proper server
Anyone know how I can contact @A.I.V ?
Your lucky your works with wifi
Which Sonim is it?
It probably won’t work but if you haven’t already, try contacting T-Mobile, they might not help you but if you have the time then try getting to them
does anyone know how to get contacts off of a qin f21 filtered by fig?
when trying to export it doesnt do anything
Is there a ADB command to remove a Samsung account from a tablet? I tried installing Techloq and it failed because the user was logged in to a Samsung account. The user tried signing out but it gets stuck.
I do not have his tablet in front of me, I logged in to his computer remotely.
Dumpsys accounts and disable the app handling them
had to do that
So not much to do if the sign out button does not work. Did anyone ever get a command to make it work without resetting?
worked for me a few times
Does it cost anything to get approved? If no, I don’t mind, if yes, I’m out.
I don’t mind selling an unapproved device.
24six will not be happy i don’t know if they could do anything about it though
Here’s the way I see it:
Can you buy an unfiltered device? Sure.
Can you download 24/6? Sure.
Is my device an android device that includes the free 24/6 app? Sure.
They should happy with the new subscriptions, and not having to deal with device breakage.
Also, that wasn’t my question ![]()
You’re wondering after an good hour or two of debugging why your custom ROM somehow removed the battery charging animations when the device is off.
You are checking binaries, init scripts, assorted kernel items, etc…
Nothing’s working.
You are ready to throw in the towel and just make that the device turns on when you plug it in automatically.
As a last resort, you decide to ask @TripleU for advice.
“Check your logo.”
Turns out if you remove the charger pngs two months ago in a tired session at 2am, you will have no charging animation.
Who would have known?
New guide incoming: “How to remove inappropriate charging animations”
