the issue your most probably having is the fact your using android go
try sideloading the apk
So why did I get that message? You used an apk or you got from the play store?
your using a cat s22 which is android go
there are some apps that dont officially work with android go
Apk will work?
ARM64 play dl link, is the cat ARM64?
Download
Not sure. How can I know?
adb
Or just try installing the apk
huh?
Tried. Got an error. I guess it’s not arm64.
apkmirror
Universal
Worked thanks.
https://forums.jtechforums.org/t/jtech-homepage-redone-open-sourced/5726?u=dev-in-the-bm_2.0
Those reviews on the homepage are fake, right?
Bro they are real :flushed_face:
Oops.
Kidding their not
(Respond to the post while being sure to maintain a respectful approach.)
Say something like:
  • Is @ars18 going crazy?
  • Did he just post some sort of template by accident?
  • Is this a secret message? Maybe there’s some sort of invisible text?
Looks like it was an auto post when I made the category
