ah in that case use the i’d go with ventoy just be aware that not all distros support persistence
You can use YUMI
It’s the easiest way to configure Linux and everything is erased after every shutdown
Think that compared to rufus it’s much better as it has direct download links for any ISO.
Correct me if rufus also has.
ISO the APK found on F21’s stock ROM for
MTK Engineering Mode
Take it from stock on dietdroid.
Could not find the app - where’s it located?
whats the difference btwn a super and system?
ik most roms you flash a super, but dumbdroid you flash system…
The system is included in the super
The super includes a system vendor and product
and most roms also change the vendor and product?
Yes.
(Doesn’t necessarily mean that it has been edited, but it’s being flashed.)
so why would you flash a super if its not edited?
If the system was edited but not vendor or product.
Why you usually flash the entire super? I don’t know.
Because your phone bootloader doesn’t see a file called system its in the super together with the product and vendor
Would it be possible to make a GitHub Worker that tracks a thread from a PhpBB forum (ivelt.com) and when a user adds a link to that thread the worker will automatically print that page to a pdf and save it or add it to internet archive?
Use case is that some people like to test the boundaries of the site and sometimes write stuff that is in the grey area, and there is a thread where people post links to these threads so that they can take a look before it gets deleted.
I am looking for a way to get all of those threads saved…
This is the thread
https://www.ivelt.com/forum/viewtopic.php?t=50273&start=3575
@AyilMeshilesh
What is this whole “New General” category
All categories got a ‘new’ of them.
The topics are moving over.
Yeah but why? @admins
Restructuring
you can just flash super in fastbootD…
