does anyone know if a google app stub works on the qin f21 running 1.1.1
i made a stub but AA just says it needs to be updated. i assume that can be fixed by changing the version of the stub???
yes
for those interested heres stubs for google mapps and the google app. works on qin
Did you ever figure it out. i am really missing out on this and dont want to spend a ton of money on a fig just for android auto, when otherwise the tcl is working out just fine.
thanks, but im not that good at this maybe you can break it down a bit. regardless will i run into update issues?
The update thing was for a different project. But probably.
I wish. there was a post by @NotABird where he started giving some very brief instructions and promised to provide links to some of the required things at a later date, but apparently, he forgot about it.
He did. He gave instructions on how to load LSposed modules on first boot. Different then @Darth but you could definitely go that way
Also this is very TCL (or or other phones that you want to use micro g with) specific. Android Auto has no issues on kosher ROMs these days.
I don’t fully understand…
What’s wrong with @Darth’s ROM with AA? Not working anymore?
Doesn’t work for kefh.
What did you mean by “this Also z this is very TCL (out or other phones that you want to use micro g with) specific. Android Auto has no issues on kosher ROMs these days.”
If a phone has Google services, it is generally easy to set up kosher Android auto
Since I suspect I’m not the only one that would benefit from this info, If possible, can you please give some general tips/instruction on how to go about doing this.
(Some of the other posts are written so tersely, it’s almost as it they’re trying to make it hard to understand. (Most posts are not like that though.)
For tcl?
Yes
I’m out of the TCL world, gave all mine away, the phone drives me nuts.
Oh well. Thanks anyway.
just wanted to mention that stub WORK on the Tiq - android 13
