The app installed fine.
I have no idea.
Try removing just the icon from the app drawer.
I have no idea.
I didn’t remove the icon i made it blend in and switched the app name. Do you know which activity allows it to be launched by other app?
No idea
I could post the one that i messed with the launcher activity and the icon and app name but it could still be launched by other apps so that doesn’t really help unless you use an ifw but i would rather not do that because i want it from the app
Since we are using IFW, all we need is the launcher icon removed. The phone cannot launch the activity in any shape or form anyway.
You don’t need to change the app name.
At work, will test later. Thanks.
It makes it look better but either way i would rather not use ifw and when i change the app and icon it makes it blend in better and look nicer
Why would you not want to use IFW. It’s great
Its not as simple i feel like its simpler with one app
I disagree, but you do you.
Also my roms updates that i send are all apks that i send to my customers
If you can send APKs it shouldn’t be hard to send other files
Any way to do this without root (su)?
A friend of mine is looking for a phone that has Android Auto and Google maps - What phones can handle that?
Qin
Where can you get that Under $200 or not Possible?
Does anyone here Filter them?
if you click on a link that opens the the google app in setting than the app reapears in setting until the next reboot
Can anyone make a guide for getting AA to work on the TCL?
If there is one already, I didn’t see it. There seems to be a TON of info on this site…
I see @ars18 you have a module that disables google and maps. What else needs to be done?
Thanks in advance!
Regarding the ROMs that are currently on the site and support AA, I believe users keep that info private since nobody knows how to do it, and they are not interested in business to create a living off their free work. But hey, why not work together? Maybe users here will figure it out on their own.
