It works. I’m on Android 16, but apparently this has been around since 4.4.2. Like I said, launcher icon and settings appearance does not go away, but you can probably approach that from a different angle (removing icon or custom launcher for home screen, settings I have no idea).
Maybe the default user (the one the consumer uses) on fig is a newly created one, like a managed profile.
I confirmed that (at least on my phone) Android auto is not running as a separate user, it runs as user 0.
Best I can seem to do is use IFW and pm suspend. App still in launcher (greyed) and settings but absolutely not launchable.
How about creating a new user and making it default, and disabling user switching. Leave maps only in user 0, and keep the consumer in alternate user. Maps shows in AA but no icon or settings for alternate user.
They are building the firmware. They do not need shtick like pm disable etc to block you from opening. They can modify the framework to never allow launching of activities from Maps unless it’s in AA and modify settings launcher etc to not show it
I got a new working on boot (user 10) and doesn’t look any different than normal (aside from the fact that I had to use a different launcher, the normal one wouldn’t start)
AA opens from user 0 shows all apps, but they are not functioning properly
Would this work i modified the manifest set everything to android:exported=false except anything that had car in the activity messed up the launcher activity renamed the app switched the icon to make it blend in in the app drawer and it doesn’t launch even when called by other apps. can someone please test it i don’t have a car? Maps for AA by anonymousfliphones
