thank you so much worked!
how do you remove embedded browsers using mt manger
I use my Android tools to locate and test the browser activities and then I use Mt manger to set those activities to zero
can you elaborate i have zero experiance in this area what android tools do you use? (sorry for nagging you
Can you share both apps?
What is IAB? I use Aquamail the tcl email didnt load all my emails.
IAB stands for In App Browser
is there a way to remove in-app browswers from an app?
Aquamail does not have any in app browsers
Yes. The question is how.
There are people out there that can do it.
I’ve done it a couple time’s. It takes time and patience, trial and error
how do you do it
In short, finding the browser activity and setting the value to 0
how do you do that? where do i find that?
For beginners:
MT manager
Arcs editor
Bool
Bool
Find the depo of that string and set the boolean to 0
my mt manger arcs editor does not work
not plus
can you post a link to mt manager that does?
MT.apk (26.3 MB)
this is the hacked one i use
still didnt help giving me an error
