Gotcha
can you give a more detailed explanation how to remove the embedded browsers
toda/shkoiyach
Which string am i looking for i am in resources.acrs
Donât waste your time with those apps.
Thereâs a way simpler way to disable in app browsers: Lucky patcher.
I tried that but it doesnât work fully
Which app are you trying to remove browsing from?
Any
What do you mean that it doesnât remove it fully?
Which permission do you remove because when i did it it didnât work
I didnât remove permissions, I disabled activities.
That also doesnât always work
I disabled in app browsers in a bunch of apps with lucky patcher.
What was the permission called
Sorry what were the activities called
Every app is different.
