Follow the flashing instructions
why cant i get zygisk enabled? it used to work i think….
If I flashed the old and my speaker doesn’t work can I just flash the boot of the new?
Boot, dtbo
Thanks will do. Can I also flash the Israeli original bands for to work properly in Israel?
Sure, flash after 6.1.3
Btw I had a phone that speaker didn’t work on both (old/new)
Thanks worked perfectly love the ROM btw I’ve tried a bunch and it’s probably the best
i just restated the phone and then i was able to turn it on
thanks anyway
I’d need the firmware, date of installation, and flashing process to tell you anything
Well I flashed work your flasher and how do I check the model again? (I just flashed both ROMs last week)
Have a backup of the original firmware?
Who does that…
(Btw the speaker never worked)
Me :slight_smile: first thing I do
If the speaker never worked at all you probably have a hardware issue…
I guessed… it’s not my phone but I never had that before…
Try connecting to Bluetooth and then back off and it may start work.
That’s my experience with a phone that the speaker didn’t work.
Why do I get device certified in google play but still no rcs?
Having the same issue…..
Try updating keybox, I just gave the tools for integrity, but it must be maintained.
Keybox must be maintained or Pif injection?
