Both
I have valid keybox, ran fetch on pif, cleared cache and storage for messages, play store and play services. Play store says certified I pass device integrity and still can’t get rcs to work
I don’t know
should i try shamiko meaning will it break your setup at all?
is there a way to get the israeli modem files without flashing the israeli bands on and just put the files in the backup stock modem
Flash the non root boot.img and everything will work
Does it show that “zygisk“ is on?
I don’t see how that wouldn’t make it worse.
if it’s not rooted it shouldn’t have the problem bechlal’, no?
I don’t know why nobody gets that these Chinese phones are never certified. Have to work to get it running and it’s a game of cat and mouse.
Of course
They’re also an issue with unlocked bootloader
On these phones there’s issues with locked bls to…
First of all, no play store, second, it wouldn’t matter anyway.
So what’s pshat some people get it to work and some don’t?
If it’s the same device and same ROM and one user can and one cannot, and it’s in the same timeframe, it’s most probably a user error.
So what could I be doing wrong
I don’t know. You’d have to list in detail what you have done so far and how you’ve done it.
Enabled denylist in magisk added messages play store play services carrier services to denylist. Fetch on pif(tried auto and GitHub). set valid kb through tricky addon, set security patch, select from denylist, cleared data from play store play services carrier services and messages
