All options in play services are checked off. Just spoof build and spoof build Play store. I get basic and device
That’s all you are gonna get for now until there’s a new keybox
And I need strong? And I’m assuming anyone who has it here set it up before keybox got revoked?
For rcs? No
Then I just don’t know
Why do you need root? I had the same issue so I flashed the non root boot and RCS is working perfect, it doesn’t care if play store is certified.
I get this error when running flashall.bat
`Rewriting vbmeta struct at offset: 0`
`Sending ‘vbmeta_a’ (2 KB) OKAY [ 0.005s]`
`Writing ‘vbmeta_a’ OKAY [ 0.003s]`
`Finished. Total time: 0.014s`
`Sending ‘vbmeta_system_a’ (2 KB) OKAY [ 0.005s]`
`Writing ‘vbmeta_system_a’ OKAY [ 0.003s]`
`Sending ‘vbmeta_vendor_a’ (1 KB) OKAY [ 0.005s]`
`Writing ‘vbmeta_vendor_a’ OKAY [ 0.003s]`
`Sending ‘dtbo_a’ (8192 KB) OKAY [ 0.201s]`
`Writing ‘dtbo_a’ OKAY [ 0.105s]`
`Finished. Total time: 0.311s`
`Warning: skip copying dtbo_b image avb footer (dtbo_b partition size: 0, dtbo_b image size: 8388608).`
`Sending ‘dtbo_b’ (8192 KB) OKAY [ 0.202s]`
`Writing ‘dtbo_b’ FAILED (remote: ‘This partition doesn’t exist’)`
`fastboot: error: Command failed`
Working fine?
Wdym ? I just did everything manually
No, I meant the phone working fine?
Flashing dtbo_b was just an idiosyncrasy of mine
Was wondering never saw a phone with a “b” slot
I did it via fastboot/mtk and it fixed it
How do we get rid of the weird alipay stuff
Did you use the rooted boot? I’m assuming not?
non rooted, why ?
That’s why. There is a resetprop that puts “gms” into ro.product.name (if I remember the prop correctly) that gets rid of the weird screen.
When I tried to build into the system itself, it messed with certification and integrity, so I left it as a resetprop.
i vaguely remember dealing with it when playing around with the ROM, easiest way to remove disable it in config xml but i cld be wrong
You can also edit the launcher APK to return true to “gms” in that prop
Didn’t work for me
On the left of the page wechat and alipay?
Follow the flashing instructions
Isn’t there a simpler way to check if I have the old one or new one?
And am I good to flash the new one either way, or I’m gonna mess up?
