Flashing the new one on the old shouldn’t cause issues, though there was one guy that said it did, but that doesn’t make sense to me.
That one report was the only reason I made two two ROMs.
What’s the keybox and Fingerprint for?
Is it making banking apps think I’m not rooted?
Not specifically banking but yeah. The ROM was made a while ago, you’ll have to updated the keybox (fingerprint too), there’s no way it wasn’t revoked.
What’s the difference between the keybox and Fingerprint?
TBH, I dont know the word salad to explain it, and would also need to check up things to verify.
Fingerprint is your device identifiers.
One thing to mention though, tricky store does not actually give you a keybox, it just gives Google what they expect from a device WITH a valid keybox, as far as I understand it.
i complained about it, but in the end i flashed it again and it didn’t make any problems. So yeah…
@ars18 maybe take off the old one, so people shouldn’t get confused.
No harm done if I leave it
Just flashed it, thanks much.
Just wondering if there’s something I can help, that the stock bands should be able to be switched on the fly, as I think that would be very useful.
Just tried the module looks like it’s working to flash back USA bands (can’t know for sure cause it came with USA bands…), but not working for stock bands.
@ars18
Google Play certification was giving me a hard time so I reflashed, updated both the pif module and tricky store module, fetched in pif, set valid keybox in tricky, and it’s still not certified
Any eitzos?
Afaf
Did tricky store say valid keybox found when you selected choose valid keybox?
Similar, “valid keybox set successfully”
Set magisk denylist, then set from denylist in tricky?
What exactly should I set the magisk denial list to?
Play services
Not all though
Now it’s saying no valid key box found.
(should I be doing anything to the Play store?)
Give it a day or two and check tricky again
Modem utilities does not work properly i flashed the israeli bands and i went to band mode and all the boxes were empty there was not one check is there a new update or something like that
Band mode? Did you take a backup before? Doesn’t come with any files.
Also Manny reports of it only working to flash us bands but not the other way around.
Also tested it, only works for US bands.
Is there something I can help to fix it, or too hard?
I think it’s a very useful feature.
