i backed up the israeli bands to stock file but us bands worked normaly when i flashed it
Dunno, check it out
Trying to change to stock dialer, says remote was denied superuser access. Any way to regrant access without adb?
Open magisk in more settings and go to superuser tab, grant there.
The phone no longer flashes certified any ideas what can be done ?
What do you mean
I tried flashing using the guide and all but couldn’t get play store certified any idea what can be done ?
It’s old. Update fingerprint and keybox
Needs to be maintained by you
Still no go I’ve been trying for a couple days already
Say what you tried
I tried updating tricky store and play Integrity and then I fetched and vailded the keybox and still not certified I also waited a few days like you said
Did you follow this?
Also, update the modules.
TBH, on my OnePlus 12 I think I’m having the same issue, but I only just noticed now because you mentioned it. Stopped caring. Maybe they are fighting back harder now? Who knows
I tried all that thank you for the ROM amazing job just wondered if you knew of a fix
I’ll have to try a different time
Sorry
Did you update the modules to latest? Check in magisk if there are any updates available
Is there a way to use the keys in Google dialer and on screen keyboard for everything else?
Maybe the keybox has been revoked… Try to set a new valid one
Are you using a verizon imei?
@TripleU Following the video linked above by @ars18 , I am experiencing an error in updating the keybox. I will post a screenshot in a couple.
@anonymousfliphones I am using the IMEI that came with the device. Does the security check look at the IMEI?
