Ty. To be clear: I already have 613 installed. When you say flash the 613 rom - do you mean a “Clean” flash, as in clear user data first?
I would try update fingerprint+key box
Denylist magisk play store and gms, keep default toggles
Clear play store and messages
Reboot
After that I don’t know
Oysh. Been there done that. I suppose I’ll try reflashing “clean” and see what happens…
Yes! A full flash from scratch
Oh wait, you never formatted after flashing?
isn’t h20 att and now your on verizon
i always had trouble on verizon i think its the service try with a verizon imei
It’s definitely root.
Worked on tmobile and att mvnos
Nah
correct.
Will do!
You can try 6.1.3 default imei to test
It’s an e4810
Uninstall all updates to Google messages make sure play integrity fix and tricky store are updated then update Google messages
Thanks. I have a stack of broken E4810s here (and many others…) so that’s not an issue. ![]()
That’s an idea… Probably better to try to verify on the older version actually, and then update after verification succeeds.
I have a feeling I know what you were doing ![]()
We are one and the same
I had the issue it worked to fix it
@sh7411usa did you get anywhere?
Mmmm hmm… (Broken, as in bricked
Lets just say I haven’t “broken” any in a while…
As for the F21 RCS. So far nowhere, I tried all the solutions offered here. I just going to pull out a brand new and sart from scratch… I’ll report back
Edit: No luck. I have not managed to get RCS working with US Mobile (Verizon) on 613, with or w/o root.
Its a qin, why are you verizon?
Have done this numerous times and everything works.
can you pleeeeaaaase share? if you don’t want public then dm
