Didn’t need to be fixed…
Dunno what to tell ya
Can someone explain what will be the difference with root or without root on the phone because I flashed my device with root and I’m not able to send quick pays from my banking app so can anyone explain what’s the advantage of having root or how to fix this issue
Welcome
I dont think the non rooted version works properly
but you can go on your device to settings> more settings> launch magisk> settings in the top right corner > configure denylist> and add the app that is giving you issues that your phone is rooted
Thank you but I tried it and it still doesn’t allow me to send a quick pay
Try uninstall the app and reinstalling add to the denylist before you open the app
Is there a guide on what to do my friend gave me his qin to make it work in America and I don’t know where to start
first post in this thread
write down all info just as in the old xda guide with snwritetool
Um could be I’m spaced out but the first post is not a guide. I don’t know what the xda guide is and i don’t know if my phone the new version or the old one.
the downloads in the post are zipped folders, in it is a .bat file, click and run.
as far as version… @nooch?
just know, its pretty hard to fully brick a qin…
okay i did all this now i went to play store to update apps and it says error retrieving information from server am i supposed to do something before this
Make sure the data and time and timezone are correct
okay i changed it still not working
it says device is not certified
working now!!!
How can I install the correct drivers to flash a phone?
download → unzip → click
Thank you so much
Worked perfect
Does this ROM have the accessibility issue?
No, and don’t forget to install the updated “more settings” apk after ROM install (linked in top post).
