now that we can lock the bootloader, if its unrooted should pass play intergrity automatically no?
also when i press set valid keybox in trickystore, it says to check my connection. i have data and wifi…
No
It’s not this phone or the ROM, ppl having issues now.
Get a keybox and set it manually.
how do i get one?
also should i update the modules from magisk?
also where can i see which levels of integrity im passing?
RCS works fine for me right away, and also did on unrooted dumbdroid…
curl -Ls "https://raw.githubusercontent.com/Yurii0307/yurikey/main/key" | base64 -d > keybox.xml
Play store dev options
uhh assuming i run this in command line? windows
So?
the main question was the first line. was just saying
i dont know command line at all
output
C:\Users\eliez>curl -Ls “https://raw.githubusercontent.com/Yurii0307/yurikey/main/key” | base64 -d > keybox.xml
‘base64’ is not recognized as an internal or external command,
operable program or batch file.
Then use termux
was it meant to return anything? am i meant to do anything after that? reboot? didnt change anything…
huh, well i was able to log into cashapp with just basic… guess that all i need!
the one reason i needed integrity lol
thanks
yeah sometimes that works
i ran flash all.bat and now it wont turn on or respond to any buttons. mtkclient still sconnects though any way to save this qin
do you have a full backup of these type of devices because i only backuped some of the parttions.
i flashed the original boot and lk so what could be the issue. the scrren isnt even turning on at all when ihold power
also this device has an efuse parttion not sure if that relates to the problem or even what that is
Any way to get into recovery and do a factory reset?
