Look on dietdroid.com
all i have is mtkclient
i dotn think that is the issue becasue the flash.all bat flashes userdata
I flashed this twice and both times I needed to reset user data.
can i reset userdata from mtkclient
any ideas because all i have is mtkclient. the screen wont even flicker so i cant boot into anything
I’m assuming you did it on a new qin
On mtkclient, flash your versions preloader.
How do i click yes and then the fastboot mode?
Explain
Really not understanding how to flash the file on when I do it. It always gives me the same error every time? Rewriting vbmeta struct at offset: 0
Sending ‘vbmeta_a’ (2 KB) OKAY [ 0.005s]
Writing ‘vbmeta_a’ FAILED (remote: ‘not allowed in locked state’)
fastboot: error: Command failed
Apparently your bootloader is locked
I see you asking on the other thread how to identify which f21 you have.
Please don’t flash any ROMs till you are sure
@ars18 @kosherboy @TripleU it seems the issue I’m having is there the bootloader is locked? How do I unlock it so I can then use the bat file to run everything?
Use MTK client to unlock
OK, I’ll try it. I’ll let you know.
Which button do I hold when I’m trying to unlock it the back button or owl botton?
Which version do you have ?
You have to know that first
how do i figure out?
The old version back button
New version owl button
Don’t flash until you know what version you have
