On top of the send button?
Top of the send button like this funny circle with like a cut in the middle? And then on top of the end button, I have a back arrow.
Yes but make sure you know what version you have
So according to what I’m telling you, what version do I have?
That won’t tell you what version you have all have the same button layout
First things first. FULL BACKUP
Or later you will be asking here how to peice everything back together…
Full backup with mtkclient (don’t need user data, skip it)
Oh, you already unlocked it using the owl botton, error came up when I was using the flash_all.bat
Brand new device, no need for the data.
Why am I receiving this error?
The error I got in the log is:
Rewriting vbmeta struct at offset: 0
Sending ‘vbmeta_a’ (2 KB) OKAY [ 0.006s]
Writing ‘vbmeta_a’ OKAY [ 0.003s]
Finished. Total time: 0.017s
Sending ‘vbmeta_system_a’ (2 KB) OKAY [ 0.005s]
Writing ‘vbmeta_system_a’ OKAY [ 0.003s]
Sending ‘vbmeta_vendor_a’ (1 KB) OKAY [ 0.006s]
Writing ‘vbmeta_vendor_a’ OKAY [ 0.003s]
Sending ‘dtbo_a’ (8192 KB) OKAY [ 0.185s]
Writing ‘dtbo_a’ OKAY [ 0.133s]
Finished. Total time: 0.324s
Sending ‘dtbo_b’ (8192 KB) OKAY [ 0.181s]
Writing ‘dtbo_b’ OKAY [ 0.127s]
Finished. Total time: 0.313s
Sending ‘boot_a’ (32768 KB) OKAY [ 0.761s]
Writing ‘boot_a’ OKAY [ 0.513s]
Finished. Total time: 1.281s
Sending sparse ‘super’ 1/19 (131068 KB) OKAY [ 3.101s]
Writing ‘super’ FAILED (remote: ‘sparse image size span overflow.’)
fastboot: error: Command failed
Which version of the device do you have ?
Do you know?
I think the new one, I have no way to figure out, can you please let me know how I can figure out?
Check here we have all the info we know how to identify which version
This ROM is not compatible with version 3
I was talking about the rest besides userdata, this way when something like the above happens it’s a coupla clicks and you’re back to square one.
You’ll be fine regardless, it’s just gonna be harder now.
I have the plain Qin logo so its V3, so whats my options for the best ROM working in america?
You have V3 because you unlocked using the owl button
That Version can not be made work in the USA
Is it possible to still buy, V1 or V2?
Very hard to get I believe
So what do buyers do?
Now since the ROM went on partially the phone is stuck in a boot loop now with the flashlight turning on and off and the QIN screenshot showing funny pictures while it reboot every time? How would I be able to get it out of this and just back to regular use like without any ROM changes?
