and
Usually whatever I edit in the system UI comes up by the notification toggles as you can see in the first picture that hotspot is already listed but for some reason it’s not showing up in the first picture
Remind me in a couple of days
How did you add a search bar in settings? I remember hearing once something in Build.prop? What do you add?
It’s not a search bar you press any button and it brings up the search bar
Well how do you add that?
I’m having a hard time getting past basic integrity, using the latest keybox. Any ideas?
Arsc edit i think framework.apk
Its technically already tomorrow, but for me its still today.
Sent a pm
The physical keypad is supposed to work in Google dialer? It launches the app from home screen but doesn’t work afterwards.
You inspired me.
If its not updated it works
if it is updated it only dials the first number
Replace SystemUI.apk with one from 1.1.1 or any other ROM that has it.
Anyone else getting Communication Error 11 on Android Auto latest version?
what is number of the error
I’m lately having issues with my Qin that Verizon is starting to make some problems does anyone know how to fix it what to do
I don’t know if it’s possible but the Eco phones are working very well with all service providers I was thinking maybe if there’s a way to put in a Play store in the eco flash file and like this the service will work well
You don’t see what I wrote?
