Flashed someone’s phone for them and changed back to original imei, and Verizon not working…
Did you do this?
Yeah.
Do I need a Verizon imei? Cdma-less?
Imei I dunno. Cdmaless yes
K better question. Obviously need cdmalesa. Is it true that if its not a Verizon imei you need to enable it every month?
Edit: wasn’t able to respond b4 you ![]()
Which service? Verizon direct? Mvno?
Re flash us bands
No reason.
Huh???
do you have a Valid keybox ?
I couldn’t get past basic integrity on this rom, let us know if you can
key51.zip (7.3 KB)
maybe a keybox will help but i can`t find one.
Here ![]()
No searching needed, I uploaded one in my reply to him.
@yossii the zip file has a keybox.
It doesn’t work
@ars18 when you built this ROM, how did you deal with platform signature matching for priv-apps (e.g. settings)? If I want to replace or mod /system_ext/priv-app/MtkSystemUI/MtkSystemUI.apk is the fact that it will not be signed with platform keys going to be an issue? I tried replacing 6.1.3 systemUI with the one from AIV rom because that one supports hotspot tile - but the app wouldn’t start (weird experience using android without system ui, somehow broke adb as well). Thankfully, was able to restore in a couple seconds using my backup apk and fx - didn’t have to reflash - but point is, am I correct in assuming this is a signature issue, or might it just be that the apk is incompatible with the ROM for other reasons. If it is signature - is there a better way to do this than LSposed/CorePatch? And if not - I guess I would have to decompile both apps and look at the differences, and then modify 613 system ui to support hotspot tile. Bottom line - and sorry for the megillah - what’s your take (and anyone else who can offer insight)?
Very possible it’s just some compatibility issue.
Tbh, I’m not the one that modified the system apks in this ROM, maybe @TripleU can help.
As far as resigning the ROM, that can be done, but it will break you ![]()
Rather edit the existing settings apk.
Send me the apk
Here are the system UI apks from AIV and 613
Does the swipe down notification UI actually live in the settings apk? Its going to be a shtickle kreeech to extract that - so let me know.
