The keybox works the problem is the rom
Try this. Might need to go deeper in other areas of system but this may work.
https://files.dietdroid.com/apks/MtkSystemUI-613-patched.apk
After replacement and reboot, you will hopefully have a hotspot qs tile.
You can test with a magisk module as well.
The google dialer app in this rom is great! It’s first time I ever got visual voicemail to work on the qin, where is it from?
Don’t remember the source. Just regular Google dialer
Want to try this?
it works well with keypad. one thing the stock app has over it is the call recording, but I modded the google dialer to have call recording. Is there any features the stock dialer has that the google dialer doesn’t?
whats the upload size limit?
For the forums 1mb
Care to upload it to a Google drive?
Yo! I only use the stock because of call recording… Care to share?
You can use an lsposed module, possibly zygisk module, but lsposed more reliable. Unless he missed the actual apk.
It’s not enabled in the US, but otherwise…
Also also also… Hotspot qs tile?
Nice. Have any more details?
For the call recording?
ya ya
Just tried it using module - not hotspot tile. Take a look at the module, possible i did it wrong.
MtkSystemUI-613-patched-magisk-module.zip (6.7 MB)
adb shell ls -lZ /system_ext/priv-app/MtkSystemUI/MtkSystemUI.apk
adb shell sha256sum /system_ext/priv-app/MtkSystemUI/MtkSystemUI.apk
adb logcat -d -b main | grep -iE 'HotspotController|HotspotTile|qstile.*hotspot' | tail -40
Patched apk should match:
67d9f86fa79a143a7d021798d4934fb1226289f507796c6f2dcff2e11f851aa8.
Could also be needing a refresh if this is the solution, on Android 9 I had similar.
Can you give me framework-res.apk?
services.jar as well if that doesn’t work
Why can’t I just download the ROM? Meh
The GitHub doesn’t have any releases, the lsposed I’m getting an error: missing capture audio output permission
here is the google dialer apk (i had a rough time getting it to start and end recording without announcing it). I also made a tiny apk that ads a hotspot tile in QS, here is the hotspot apk and permissions xml as a magisk module hotspot
Nice. Very cool
As for hotspot, he’s trying to enable it natively.
Btw, @sh7411usa , the apk from aiv is signed by duqin and 6.1.3 is AOSP test-keys.
