Is there a reason why it’s not working for me? Mos of the time it isn’t even say vowifi on the status bar and even when it why I call it says server unreachable
Maybe your carrier has to support it
T-Mobile…
4 posts were merged into an existing topic: Verizon MMS protocol issue (voice note/video not playing)
2 posts were merged into an existing topic: Verizon MMS protocol issue (voice note/video not playing)
2 posts were merged into an existing topic: Qin F21 Pro Version Identifying Help
Anyone know why Strava app is not working in the 6.1.3 ROM?
Does it make sense that Wi-Fi calling it only works on 5Ghz Wi-Fi and not 2.4
No
Welp. Metzius
For some reason I’m having issues with my Verizon SIM card that it’s not working well on my phone and I have already the updated ROM that fixes all the issues and I know that the Eco f30 doesn’t have this issue you can pop in any SIM card and you don’t need to call Verizon to activate CDMA less I want to know if there’s possible to make my phone the same or is there a different file than I can flash my phone with it should work as the Eco f30 I should be able to take out the SIM card put into SIM card shouldn’t affect anything it should automatically work
The cdma issue isnt something that was fixed in 6.1.3.
The thing you need to do is call then up.
If you have us mobile then you need to call up once a month unless you switch your imei.
I called him up the IMEI number is compatible and for some reason even they enable CDMA less it doesn’t work properly I want to know if there’s a way to flash the phone with a certain realm that it will work like the Eco f30 that you don’t need to do anything you just pop in any Sim and it automatically works
Anybody ever try an f30 IMEI on f21
Yes it works for regular calls and text but RCS doesn’t work unless you have CDMA less enabled
I had that issue many times try calling again for some reason not every rep knows what it is
If I don’t care about Verizon support (only at&t/T-Mobile) is it better to use dumberos or this ROM Version?
Depends what you mean by “better”. What’s your goal?
i am trying to flash a phone and i got this error no matter which DA i use anyone had already this problem??
Never saw that try using fastboot
@moderators please move the f21 general thread
