The smoothest easiest to use ROM currently available for day to day use.
I don’t know about service providers on dumbdroid.
Assuming the carriers you mentioned work, it is mostly down to preference.
If you are focused on best possible security, then dumberOS.
Is it possible to make a .bat for Linux? Would that be a shell script? No clue about these things
.bat is for windows only
Is there an equivalent of double clicking a file on linux to run a command in the terminal?
sh with a shortcut. Some os’s will ask if you want to run on double click like mint.
Ik I meant the equivalent
Is someone who knows this stuff able to make one?
Or share the .bat and I’ll ask ai to
For what
It’s not just the script, there are some windows programs in the folder that the batch script runs, you will need to replace those with the linux equivalent
Linux mint iso
Besides adb??
Yup. sqlite, makef2fs and a few others
Absolutely no idea what’s you are going with this.
linoox
I though you meant what am I gonna use it on
Basically, bkitzur, my current workflow is that I use an Linux ISO for mtkclient to backup band partitions, then switch to windows to flash the rom, then back to Linux to flash band partitions.
That’s a hassle, so I’m trying to find out if I can do it all on Linux.
Course you can
you can also do it all on windows - just pointing out. setting up mtk client once on windows is much less of a hassle than rebooting into a live iso everytime you need mtkclient, especially if you are doing minimum twice per device
That is the question. How, as
I tried for a long time, was never able to get mtkclient or fastboot to recognize the device. Drivers… (Yes I installed them)
And
Not if I can flash 6.1.3 on Linux…
In hochi nami (loosely - true, true), I admit it’s a hassle. However, I crossed that bridge once and use mtkclient happily on windows all the time. Aderaba (here - in fact), getting it running on linux with python venv was also a tircha (pain in the neck).
He claims he has a problem with the drivers
If there is a problem with the drivers mtkclient will not work
Why is it so complicated to configure mtkclient on Windows???
