Wanna tell me how?
I asked AI a bitโฆ and he says that there is a replacement for all the necessary tools in Linux, and it shouldnโt be a big problem
He gave me some script, Iโll check it out later this week when I have a device
Iโm not that afraid that it will go into Brickโฆ ![]()
Look again at @TripleU 's guide that @The-curious linked. (I see you replied to it last year, so this wonโt be your first time reading it). There was one more trick that I didnโt see documented anywhere that I had to do to get it up and running, Iโll write it up bli"n when I get back to my other PC.
Have you seen the automatic installer?
Hey @Zvi_Wolf
That was way back when I actually knew nothing. Even less than I do now
I donโt know if this is a chiddush to me it was but I found a search bar for settings. Go to Settings>apps & notifications>default apps, click on the 3 lines on bottom right corner
Good spotting!
Technically, there is a search activity built into the settings app. This guide shows how to trigger it from the main settings screen using the number keys.
Essentially, it is just firing an intent to launch the search activity. You could theoretically achieve the same result triggering the intent via adb:
adb shell am start -n com.android.settings.intelligence/com.android.settings.intelligence.search.SearchActivity
You could map a button or build a shortcut to that component as well.
The flash-all.bat flases all pertitens???
For sure everything you need for 6.1.3 and the us bands.
Just remember to backup your imei (and wifi and bt codes)
My magisk app shows up on the home screen is there a way to hide it?
Is there a way to do this after I already flashed us bands in to the Israeli f21?
Donโt understand your question
I want to be able to access the magasic app once I already changed my bands on a Israeli quinn f21 but I didnโt add this apk to have more settings in settings so i want to know if i can do it now without needing to reflash all over again
This apk is for 6.1.3 only
Never mind I was able to get it thanks
Is there any problem with doing a update in magisk regarding if it can ruin my bands I flashed or anything else?
