You can update magisk but it will appear on the home screen.
Won’t ruin your bands.
K thanks is there any benefit from updating?
Absolutely nothing on the f21 pro
im sorry I’m new to magisk do I need to do the install on the top
I don’t know what’s going on in that screenshot.
I updated. Any way to hide it on the home screen?
On the top it says install I want to know if I should install wtvr it’s saying. Not to do anything update
No, not unless you build from source or edit the app, uninstall old and repatch boot+flash.
Why are you guys updating, what are you hoping to gain?
Doesn’t look like you are rooted to begin with
I’m not trying to update I just want to know what it means on the top when it says install
It has to be that I’m rooted I flashed on us bands
Flashing US bands does not root your phone
Are you on 6.1.3? I’m assuming not
Yes your right I’m not on it my bad I thought you have to be rooted to flash bands
Yea I never changed the room or anything on it. It’s the Israeli one kosher play it’s 2.0.8
Wrong thread… Post on F21 Master thread
You also won’t get support here for kosher ROMs
And yeah, it probably is rooted, magisk modified to be allowed in system, but the UI logic never changed. It’s what I assume.
Ok thanks
“Updated” was the short version. I hid magisk in the app but unhiding didn’t work so I uninstalled the hidden magisk app and when launching magisk in extra settings had to reinstall and it showed up on home screen.
You can extract the magisk apk from the ROM, uninstall your current, then install mine.
I believe this is where I kept it.
adb:
adb shell pm uninstall com.topjohnwu.magisk
adb shell pm install /system/etc/magisk.apk
I believe that’s where it is, check.
You did the reinstall by flashing it?
