Yep was there.
No, the magisk launcher prompted to reinstall
All good?
Yea it only does that if you already once had it all set up and did a software update and now i see also if you uninstall
Yes. Thanks!
Is this a magisk module? I installed it and it boot looped
Yeah it is. On 6.1.3?
Other ppl have used it before
Okay so I will try again (thanks to your wonderful guide I have no issue reflashing)
Update: did and worked with no issue
Happy to hear
I donโ€™t know how I missed this go into settings in app thereโ€™s a option to hide from screen
Which file is the list of websites the rom blocks?
Why do you think it blocks anything?
Thought I saw people calling it kosher rom
Nope just an open ROM.
Does anyone else have this issue, and does anyone know how to fix it? Sometimes when taking a screen recording, when you end it, it says, โ€œError: could not save the screen recording,โ€ and it just deletes it.
See attached error
Could you send a screen recording of that error?
A. Do I need to change the IMEI for it to work in America?
B. Does the connection (port) matter?
C. I want it to work in Israel as well.
Welcome!!! :waving_hand:
To make a qin f21 work in the US you need to flash the necessary bands, and of course you need an IMEI that works in the US (Global Phone IMEI)
To flash the bands you need a phone with a blue charging port, the new version comes with an orange charging port, and you cannot flash the American bands on this phone.
With this app you can easily change bands from stock to American
