Rooting a CAT S22 Flip
I have a cat s22 that I need rooted normally I would just try it myself and figure it out this one has a lot of information on it and I can’t risk losing that info so if anyone can help me I would appreciate it thank you
To be smart I would back up everything, whatever you do.
  • fastboot flashing unlock
  • confirm
  • flash empty vbmeta with this command:
    fastboot flash --disable-verity --disable-verification vbmeta vbmeta.img
  • fastboot flash patchedboot.img
  • done.
Are any of the steps different if I’m using @notabird’s custom ROM?
I said how you get root. but once the bootloader is unlocked - you can flash the super…
Does anyone have this for the Cat S22?
any
I don’t know anything about rooting (check my bio) can you elaborate?
Do you mean to say that there isn’t a specific patched boot for the Cat?
patched vbmeta. patched boot for the cat you do it in the magisk manager app. patch it with the new v29
did you mess up ? is it really fastboot flash boot patchedboot.img?!
You are correct
Unlocking the bootloader will prob erase everything on your phone.
I flashed a patched boot image onto my Cat. My cat has @NotABird’s kitty custom ROM.
Now when turning it on I get the Cat screen and then the screen goes black.
Update: It was an issue with the boot image, now it’s working.
I also run kitty2 (testing) not sure I understand how I can get and patch the image. Any assistance would be appreciated
boot_stock_v30.img
vbmeta.img_stock_v30.img
is this even if I run Kitty2?
Based on this part of his guide:
I would say yes.
Keep the stock handy, if anything goes wrong, just flash it back.
Disclaimer: I do not own this phone.
Anyone have the boot image without recovery so you can’t factory reset the phone for the cat s22?
can i root this boot and flash it wile i use v29?
