Rooting Sonim Phones
Try one click root tools.
The older the Android version, the more likely to succeed.
You could try the attached firehose with edl it worked for my sonim xp3800 verizon.
prog_emmc_firehose_8909_ddr.mbn (278.8 KB)
What do I do?
Bkerler EDL github.
Use This tool and run edl r boot boot.img —loader prog_emmc_firehose_8909_ddr.mbn That should pull the boot.img for magisk.
can you post the rooted boot?
Here is the original boot from my xp3800 verizon you can patch it.
can I use the same thing for an at&t version? after patching it with magisk, how will I be able to flash it if the bootloader is locked? I’ll have to use the firehose? is there a big chance of bricking when using edl? do I need an xml pointing the the partition?
It won’t unlock it
is there a way to unlock the t mobile xp3900???
I think so, but it will be a massive headache.
well can we make a deal?
i’ll make the upcoming app and you figure that out for me
https://d.offlinesoftware.solutions/t/apps-by-halachidev/3777/32?u=halachidev
And for the 3800 locked to non existing sprint?
It might take months.
me 2 :face_with_diagonal_mouth:
Will have to research the regulations to see if the law is actually on our side.
Might have to find a phone that fits all the right criteria to be able to force T-Mobile into cooperating.
BTW, I’ve tried before, and gave up.
But I’m not interested in either of the two apps that you proposed.
What I do want is:
Backup the files from your phone with edl patch your boot.img and flash with edl. Use adb reboot edl to boot the phone to edl.
What’s the command to flash with edl?
Edl w boot boot.img
