You have to put your file name at boot.img and use the correct loader. —loader prog_emmc_firehose_8909_ddr.mbn. Make sure your loader is in the directory you are flashing from.
Does anyone have the LiveDVD?
The official links on the Github repo doesn’t work.
Nope…
I never used it, but if I figure out how to install it properly, I can add it to the iso I made.
Was about to ask you about that.
For anyone who’s used it, anything special I should know for installation?
Once installed, does it need sudo to run?
I downloaded it a while ago, uploading to google drive
What ended up happening?
successfully rooted a sonim xp3800
edit:
i am able to install apps directly from the phone thank you @flip for the firehose
Hold on, I need a guide this second!
only have it for the xp3800
Would the firehose help me for my Xp3900 if I don’t have a dump yet?
i think its a different chipset you could try though and see what happens
only able to install through a root installer i use lucky patcher
Can you just post what are the general steps you took to root?
I’m trying to do it for so long!! can you give the steps you used? also would it also work on xp5800?
Gemini refused to help me with it, went to grok, ran out of prompts, will have to continue in the morning.
or try again Gemini with a better prompt to start. I got it to try to find me solutions a while ago (although it was’nt successfull then)
i need it for the xp3800 pleeeeeeeeeeeeeeease
