Rooting Sonim Phones
The firehose in the zip didn’t work?
prog_emmc_firehose_8909_ddr.mbn
not yet ill try again
just tried again
2025-08-21 15:34:06.913 Validating Download Configuration
2025-08-21 15:34:06.913 Image Search Path: C:
2025-08-21 15:34:07.555 Process Index:0
2025-08-21 15:34:07.564 Qualcomm Flash Image Loader (QFIL) 2.0.3.5
2025-08-21 15:34:40.328 Programmer Path:C:\Users\Halachi Dev\tech\xp3800verizondump\prog_emmc_firehose_8909_ddr.mbn
2025-08-21 15:34:40.328 Image Search Path: C:\Users\Halachi Dev\tech\xp3800verizondump
2025-08-21 15:34:51.658 Image Search Path: C:\Users\Halachi Dev\tech\xp3800verizondump
2025-08-21 15:34:51.660 RAWPROGRAM file path: C:\Users\Halachi Dev\tech\xp3800verizondump\rawprogram0.xml
2025-08-21 15:34:52.911 Start Download
2025-08-21 15:34:52.915 Program Path:C:\Users\Halachi Dev\tech\xp3800verizondump\prog_emmc_firehose_8909_ddr.mbn
2025-08-21 15:34:52.920 ***** Working Folder:C:\Users\Halachi Dev\AppData\Roaming\Qualcomm\QFIL\COMPORT_3
2025-08-21 15:36:33.127 Binary build date: Jun 25 2019 @ 03:16:15
2025-08-21 15:36:33.128 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files (x86)\Qualcomm\QPST\bin\QSaharaServer.ex’Current working dir: C:\Users\Halachi Dev\AppData\Roaming\Qualcomm\QFIL\COMPORT_3
2025-08-21 15:36:33.129 Sahara mappings:
2025-08-21 15:36:33.129 2: amss.mbn
2025-08-21 15:36:33.130 6: apps.mbn
2025-08-21 15:36:33.130 8: dsp1.mbn
2025-08-21 15:36:33.130 10: dbl.mbn
2025-08-21 15:36:33.130 11: osbl.mbn
2025-08-21 15:36:33.131 12: dsp2.mbn
2025-08-21 15:36:33.132 16: efs1.mbn
2025-08-21 15:36:33.132 17: efs2.mbn
2025-08-21 15:36:33.132 20: efs3.mbn
2025-08-21 15:36:33.133 21: sbl1.mbn
2025-08-21 15:36:33.133 22: sbl2.mbn
2025-08-21 15:36:33.133 23: rpm.mbn
2025-08-21 15:36:33.134 25: tz.mbn
2025-08-21 15:36:33.134 28: dsp3.mbn
2025-08-21 15:36:33.134 29: acdb.mbn
2025-08-21 15:36:33.135 30: wdt.mbn
2025-08-21 15:36:33.135 31: mba.mbn
2025-08-21 15:36:33.136 13: C:\Users\Halachi Dev\tech\xp3800verizondump\prog_emmc_firehose_8909_ddr.mbn
2025-08-21 15:36:33.136 15:36:23: ERROR: function: sahara_rx_data:276 Unable to read packet header. Only read 0 bytes.
2025-08-21 15:36:33.137
2025-08-21 15:36:33.137 15:36:23: ERROR: function: sahara_main:982 Sahara protocol error
2025-08-21 15:36:33.138 15:36:23: ERROR: function: main:320 Uploading Image using Sahara protocol failed
2025-08-21 15:36:33.139
2025-08-21 15:36:33.141 Download Fail:Sahara Fail:QSaharaServer Fail:Process fail
2025-08-21 15:36:33.143 Finish Download
I dunno this stuff.
@anonymousfliphones
$ venv/bin/edl --loader=Loaders/sdm662*.mbn printgpt
Qualcomm Sahara / Firehose Client V3.62 (c) B.Kerler 2018-2025.
main - Using loader Loaders/sdm662*.mbn ...
main - Waiting for the device
main - Device detected :)
main - Mode detected: sahara
But… Can you flash?
Didn’t go any further than that.
Do you have the Qualcomm drivers installed?
Download here if not https://qdloader9008.com
guys im clueless! I know what edl is but I don’t know how to even start using it. can someone help me out?
I’m a noob when it comes to this stuff, but learning more.
Did you use the firehose that is in the zip?
the firehose in the zip will work for at&t version? PLEASE WE ARE DESPERATE TO ROOT THESE SONIMS!!!
I have absolutely no idea don’t know own any of these phones
I’m curious, what’s stopping you from sharing the correct firehose or general guidance? I’m assuming there’s gotta be a reason you are not
You guys are definitely on the right track.
The firehose in the zip is the correct one.
https://xdaforums.com/attachments/xp3800verizonfiles-zip.6155479/
To enter edl:
adb reboot edl
Connect to pc and open device manager. If the phone comes up as anything but 9008, you’ve got the wrong driver.
Also, read the docs for bkerlers edl. There is a also a tool zadig that can help you get the correct drivers.
Linux is an option here too, to avoid messing with driver setup.
yes
don’t work for me tried more than 20 times
When your phone is in edl mode, what does it say in device manager? Exact words please
worked for me
xp3800?
what did you tried to did?
do you have a patch?
