just making sure the sonim works in isreal?
and how much do they charge?
Yes, depends on carrier though. If your roaming it will work for sure
Depends on the phone & carrier, probably not more then $30. You can check before checking out/putting your credit/debit card info in
im talking about using a isreal sim
It has the bands so it can work, IF, it doesnāt work, its the carriers problem, not the phone
any other legit unlocking websites?
Direct unlocks is a known scam, donāt give them anything
ok thanks, it looks so official
Why was it not removed from Google Then?
Just got to Israel tried out Hot Mobile and tripletel on the Folder 2 and it doesnāt read the sim at all, anyone can help?
Does it show a phone number in the settings?
No I donāt think so
Hi everyone, I wanted to say that I myself am getting a Samsung Galaxy Folder G1600, the original one and not the 2, I spent literally hours researching and figuring out things, so just to save everyone the time and frustration.
Iām just going to explain a little bit what I know. From ×¢× ×××Ŗ ××¢×Ŗ×. The thing is like this: 2G doesnāt work anymore in Israel. And in other places in the world as well. It works only 3G and 4G. Now, till now I had a LG Classic Flip, and it says 4G LTE,. Iām like, yes, thatās amazing! Letās go! And Iām trying to spend hours to try to make it work because it says it has 4G and I all my effort goes to waste I went through programing it debugging, developer options Bākitzur no hope.
I was about to buy another one because I thought mine maybe had a problem or maybe was forged, but then I figured out that mine does have 4G. Until B"H I realized my mistake.
What you need to take to consideration is not just 4G. You need to know as well what type of a band it is. What is a Band?
You can think of frequency bands like highways that carry voice and data signals to and from devices. Different cell phone carriers have their own lanes, giving them their own space on the spectrum. When you make a call or use the internet on your phone, your device sends and receives information using those designated lanes.
Besides Take for example Volts for an outlet in America its 110v and in Israel its 220v so you can have a company like Samsung that makes refrigerators and you would want to order one, you would understand that you canāt order it from the UK, because even though itās the same company and model but they use different voltage!!
So to are bands, each country in the world uses different bands, therefore it depends on where the phone was made. Letās say it was made in China, they put on it, letās say, Band 1, 2, 3, 5, 6, 7, 8, 66, so on and so forth, and if its origin country made is Korean, then it would have different bands.
Therefore, speaking about what we said in the beginning about the Samsung Galaxy Folder 2 does it work in Israel or America you would have to check what band it is.
In Israel I know the bands that work are Band 1 with only specific companies as Band 3 and 7 work with all!!
Now, could anybody help me with mine before it comes, I want to kasher it, but beforehand I want to be able to put on it a kosher SIM. So where can I just get all the information, how to modify my phone completely instead of needing to research this whole thing. Like, can somebody post, letās say a file or something that has all the information, how to change the IMEI so I could use it with a kosher SIM, how to download all the apps, how to kasher it afterwards by deleting the browser and putting on it your own personal filter to block what you donāt want access to so on and so forthā¦
Looking to hear from someone soon. ![]()
Thank You!!
Samsung LG Classic?? Either its a LG Classic or a Samsung Classic. Unless you have Samsung Apple iPhones in your worldā¦
Iām assuming you have a European LG Classic Flip, cause the one from here in the united states doesnāt work in Israel (anymore). Maybe its not a LG phone what you have
Remove all the apps you donāt want with adb. It runs a very old android version (5.1) so not really possible to get modern apps working on it anymore anyway
Iām pretty sure volts donāt matter when it comes to phones
The original Samsung Galaxy Folder is not VoLTE. Phone calls and text messages rely on 2G or 3G to work
You can try to change imei with this tool
Need to disable antivirus
https://getintopc.com/mobile/download-z3x-pro-full-without-box
Thanks fixed
YES Volts donāt matter by phones just taking it as a known example
Could be your right but it will still work as far as I know for all you need for calls is really 3G might work a bit slower and less reception.
No LG classic flips work in Israel anymore because the only network that had Bands 1,3 or 7 was the 2G and now they shut it off.
Since you got in to this topic Iāll add as you can see from the LG classic flip that it can have Bands 1,3 or 7 for the 2G network and not the 4G so when you buy a phone make sure it says that the 4G SPECIFICALLY has Bands 1,3 or 7 !!!
