Seeking Cat S22 Stock ROM
Does anyone have the Cat S22 Stock ROM or know where I can find it?
https://xdaforums.com/t/cat-s22-flip-revert-to-stock.4626603/
I don’t understand. All I did on my Cat was:
  1. In the command prompt type: fastboot flash --disable-verity --disable-verification vbmeta vbmetav30.img and hit enter then type fastboot reboot fastboot and hit enter
  2. Once in fastbootd mode type fastboot flash super kitty2.img and hit enter.
So why is the steps to flash back stock more confusing than fastboot flash stockrom.img?
It’s just a guide, there are multiple ways to flash
I didn’t check, but if the super is unpacked, you have to use fastbootd to flash system vendor product
I installed a custom CAT rom but the sim is now stuck on 0 bars. I think its because I didnt update to v30 before flashing the ROM. Does anyone have the v30 stock that I can flash or does anyone know what I should do?
Stock is somewhere on xda maybe here as well somewhere.
Link?
@DonBot @anonymousfliphones here ya go?
Cat S22 Flip - revert to Stock | XDA Forums
