Service abroad without roaming via WiFi calling?
It should. Just make sure you keep airplane mode on to avoid travelpass activation. Also often you need to activate wifi calling while still in service area
How would you have data? you would use WiFi?
Hence the name WiFi calling.
It should as long as your on wifi
Not Necessarily does WiFi calling mean WiFi, It can mean data.
No it can’t that would be voLTE
I’ll be honest, I am not completely sure.
I use Wi-Fi calling, but I have a problem when I try to sign in with my Qin f21 at a place with free Wi-Fi. When the option to sign in appears, it doesn’t work—meaning I can press it thousand times and nothing opens. Does anyone know about this problem?
Which Rom ?
6.1.3
When I use Wi-Fi at home with a password, it works, but when I want to use free Wi-Fi it’s asks me to sign in, and the sign-in doesn’t work. I mean, I press the button “Sign In” and nothing opens.
Add this module to Magisk
Thank you works amazing!
