SK Music: Bugs, Comments, And Feedback
See here for the SK Music - Official Releases page
For any bugs comments or feedback, you can post it here
Thank you, I can now have kosher music on a PC.
Great work!
Here is some crazy seo
https://skmusic.shalomkarr.workers.dev/sitemap.xml
Will the community search option be added?
With the word “Sefirah” I only get 2 playlists but on https://search.zemer.io/ I get much more.
I told him he should hook up the full search API I’m sure he’ll get it
Thanks alot it’s amazing!
Are you going to add a download option?
@PleaseSmileToday Thanks for your feedback - This will be implemented before tomorrow hopefully
Nope, that requires a lot more processing power and cookies and innertube and stuff
Update - There is now 2 options to search - fast search and full search
Not by a device that can check now, is fast like till now and full the community playlists?
You still have 30 minutes till “tomorrow”.
yeah - there are 2 options for it but its still pretty fast both of them
vs
the community is double and about the same speed - i will get rid of local over the next couple days probably
This is 142 ms for the remote one and 10 for half the results
is it worth switching all to complete with local fallback - idk yet but probably
Ok, I took out my laptop for this.
First of all great work, I really appreciate it and have a few suggestions.
  1. There is an option to exclude female artists, maybe if it is toggled off, there should be an option for female artists only on the left side just like “kid zone”.
  2. I take offense that there is even an option to exclude chassidish artists. To counter that maybe have an option to allow just chassidish artists.
  3. liking a song brings it to the library section , but goes into a list and that list can grow very long. How about in the library section there should be two folders, one for recents and one for liked.
  4. Option to download list of liked songs and import the lists or import custom playlists created from Zemer.
  5. If I am playing a song from the liked it shows an animation on that song while playing it. But if I go to the next song it still animates the first one and doesn’t change.
  6. Add some keyboard shortcuts for liking a track. I see that I can pause and play with the spacebar and can go back and forth with shift+right or left. Maybe write it somewhere and add a shortcut for going back and forward 15 seconds. Or make that pressing and holding the right or left arrow fast forwards it.
These are all just some suggestions, you don’t owe me anything.
im using techloq so i need everything whitlisted. any other domains/urls besides the one in the main post because none of the music is playing.
looks awesome by the way
I also have Techloq and is fully open. Maybe you need to ask them to allow embedded youtube? I am not sure how the website works.
