Small Questions That Don't Deserve Their Own Thread
What happened
Quickstep is the launcher
I know but the question was why it’s crashing.
I got a fail message I don’t remember exactly what it said.
I ended up switching the launcher.
When I try to install the driver auto installer I get this error
Dirver Installer v1.0
Do Not support Win NT earlier version
Press any key to continue . . .
And in the the mediatek USB vcom drivers folder I don’t see any thing to press on to install. Any help?
:fire::fire:
Bingo version, I like that!
:+1:
On my TCL Flip Go, how can I unallow apps from popping up notifications? I’ve been trying to search for this answer, but I might not have the correct keywords.
I don’t remember exactly but there is some sort of app on the forum that you can block notifications for apps
Pull down from the top of the screen with your mouse. You should get a notification list . Hold down the notification you want blocked and you should see an option called turn off notifications.
What’s a good and safe APK editor for Windows?
I use apk editor studio (I think its called that). It uses apktool so instead of having to run the command from cmd it does it for you. It also simplifies the editing after unpacking like instead of changing the package name from the file you can do it directly from the app. It also provides signing the app (I don’t know if that is through apktool or something else).
Safe? I dont know if your scared its less risky to use apktool directly.
APK Easy Tool
Is there any way on a TCL Flip to allow the alarm to sound, even though everything else is silenced?
4 posts were merged into an existing topic: Rooting Sonim Xp3900
Anyone with experience with TWRP on the Cat S22?
https://xdaforums.com/attachments/twrp_recovery_12_1-img.6155161/
Just almost screwed myself over with that.
Yoish. by me it didn’t work either - it worked, but no RW permissions…
