Hi does Anyone Knows Where The Network Restriction File Is Stored OR if anyone have experience unlocking It
Anyone knows, does it have good T9?
Some ppl like it some not i’m giving it 2-3 stars
Just install TT9, I haven’t found a phone that has anything better.
Link?
I give it a 1.75 stars there is no mouse unless you use c9 with shizuku which you need to restart with adb every reboot and if there is no mouse you cant use apps… And there is no recent apps
What are you rating it for?
For using it as a smartphone that happens to not have a touchscreen, or as talk, text, + media phone?
Why do you have to reboot it?
Just keep it on.
It has a great battery, can probably last over a week on idle.
That’s what I did in yeshiva, and it worked.
Latest version is 58.0.
agree it shouldn’t be like it but nowadays every basic phone must work with waze
anyone knows if i can trust this?
https://romdevelopers.com/index.php?a=downloads&b=file&id=167147
my question is if the files will work
trying to get the firehose for the xp3900
