TCL Flip 2: No Brom Mode, BUT
Schnitzel, so why would i make a ROM of mine…? Like, what’s better of keka?
Also, can I flash onto mine keka?
I don’t think you can. If I recall correctly, even the hardware isn’t compatible. (A screen from KEKA will not work with a board from the older versions)
Aha, so which one is more popular? Which one should I build off…
nothing I noticed and there probably is not.
However it may be more usefull for more phones.
Mine is brand new… anyone wanna trade for the sake of the tzibur?
Sounds right:
I once flashed a keez super and it worked. I would think flashing md3 or whatever its called would work
I got one like a year ago @mufandchush would that be a newer one that supports KEKA?
Check software version on back
It’s KEEZ
Then its old.
What is it currently running?
I looked on the back of the phone and it said KEEZ. I didn’t turn it on.
Is this true? This phone is not being made anymore. Is there more KEKA compatible phones on the market than not?
Keka come as keka and does not update to anything else so far
I would guess since keka is the one being made the other one is no longer.
We need to know how many are left on the market.
We also need to know what is compatible with the go and plus?
And @tripleu what are you planning on doing just super or everything?
We also need to do some testing because I belive just the boot is not compatible.
One time even a stock boot worked just not @netroscott rooted one though it had a keez super but I belive even if it would of had keka it would of worked
The ones on Amazon now are KEKA. (They might say 4058G but they are still KEKA)
Walmart?
eBay?
Tracefone?
Never dealt with the go. whats the difference between the two g and l?
like my story?
