Yeah probably
When I get a chance I will flash every partition on the keka to test.
Why are the partitions different than a list from adb? @Tripleu?
The ones that are empty are cancelled out.
I got 3 lying around in a drawer somewhere, I’ll check if any of them are keka. If yes, it’s yours.
Chances are not though. Got them quite a while ago.
Update:
Sorry, only found two of them, one kefh, one kee7 written on the back of the phone.
This sounds really interesting…
Can I flash this onto a TCL flip go?
is this blocked on phones that are locked or wheir made by a service carrier and then unlocked?
You need special tools, won’t work to do it with mtk client
like?
Costs money, you can buy it on eBay. One that works is infinity cm2
So this thread is a bit confusing and also it seems all the rom links are down. (or at least I can’t access the google drive links.)
From what I understand what TripleU accomplished is they made a full dump. Then it seems thye got rid of simlock? If so that’s really big news I would think.
@ys770 You said this didn’t work with mtk client. Which if I recall is the tool to get into fastboot that all the tcl flips that I’ve used are flashed. If I may ask, do you need some sort of hardware tool to then flash the rom/get into preloader, so then you can flash the rom?
I have a few tcl classics that I bought that I rooted.
Welcome to jtech
The tool used to boot into fastboot is called aurobooter and doesn’t use mtk client. Never tested the sim lock.
The link is dead.. can you pleas reupload the files again
Plz can you share me new link of this file
Thanks bro.
i don’t have it anymore. maybe it is on dietdroid.com
I have this tool but I need the file share by TripleU any one have this file plz share it..
file name: MT6739_T408DL_OSv11_RP1A.200720.011_gflip6tf_TCL.zip
I did’t found it at dietdroid.com
thanks alot
