@anonymousfliphones @ys770 anyone has a link please?
use adb push to put a .vcf file in the phone’s storage, then open the .vcf from file explorer. It will import the contacts
I cannot get gps to work on my flip, I tried in Waze and GMaps webviewer from f-droid. It has permissions, but the apps just searches for a location. Does anyone know any fix?
Used this tutorial: How to Root TCL Flip 2, Enable Debugging, Install APKs - DietDroid
First time rooting/modifying anything - says after getting magisk installed, to edit the settings but I’ve had no way and tried to copy screen into my PC and can’t figure that either. Got the ADBIO installed via browser and enabled it but can’t use command prompt to do mrepo.apk :// model number is T408DL .
Magisk won’t let me update either (to 29.2 I think)
So I need copy screen help or something?! I is this a lost cause? Literally doing this for one reason and starting to feel like its out of my ballpark.
my daughter has a cochlear implant and a hearing aid. there is an app called nucleus smart app that would connect direct to her devices. and i am wondering if its possible to get the flip phone phone that it could run on. it needs at least android 8 bluetooth 4 and ASHA which is some technology for streaming to hearing devices. any advise would be appreciated.
thanks
Hi all, Does anyone know which package to delete to get rid of hotspot? Or how I can otherwise get rid of it?
Thanks
You can try running this adb command and see what happens.I don’t know if it works on the TCL but it works on the phones I tried it on.
adb shell settings put global tether_supported 0 |
Its not system level
This works on the f21 pro, never tried on tcl.
its that one on the tcl. You need to add it
Does anyone have a boot.img for the 4058G?
(Not the KEKA version)
Or is there a specific one that will work for this model?
Thanks
i found that the regular one for the other models seem to work
What do you mean the regular one?
And btw which rom will work for this model?
(Someone used a rom repacked with the vendor.img from a backup from this modal and it worked but I’m not sure how he did it - which one he used)
Original neutron Scott
The regular neutron.img, it didn’t need a special one for that model. im assuming any rom will work if the vendor.img is from this phone, but never tried
Any rom? Not a difference between KEKA and KEFS?
The original neutron.img is for KEFS so I assume that the ROM also needs to be for KEFS
Is that correct? Thanks
the original neutron is for KEFH.
the boot image happens to work for other roms in my experience
He made one for KEFS too, I’m talking about the original one for KEFH
